Store text data into sqlite instead of stream.
richrich
Post by richrich »
I'm considering purchase of your component, does it support sqlite?
I mean simply instead of storing into stream and one file store into SqLite with different tables to easy search and filter data later.
If that is possible - have you got demo ?
Re: Store text data into sqlite instead of stream.
There is no special support for SQLite, but I believe it must not be a problem.
But native format of TRichView documents (RVF) is a binary format, it must be stored as BLOB field. So, if you want to enable searching text in DB, I suggest to save two copy of each document: RVF in BLOB field and plain text version in TEXT field.
Which components do you use for SQLite? I'll try to make an example.
richrich
Post by richrich »
As for your question about component: SynSQLite3 freeware from mORMot
Example RVF document content:
1) Red First line
2) Green Second line
3) etc. etc.
I want to quickly find specified data from db to filter/search and the same have text formatted view using your tdbrichviewedit.
So single viewedit should show data from different tables/cells.
richrich
Post by richrich »
Sergey Tkachenko wrote: Sun Jul 01, 2018 5:12 pm There is no special support for SQLite, but I believe it must not be a problem.
Is that possible? Have display in one viewedit all doc but at same time data from different sources tables in database?
I need some time to study SynSQLite3...
I created a demo https://www.trichview.com/forums/viewto ... f=3&t=9178
I hope this is what you asked for.
