Hide and show a button in a table cell on RichViewEdit
mohonko
Post by mohonko »
Hello! Help me please. I write a program in which the main component is a table created in RichViewEdit. In this table, I need a button to appear when clicking on certain cells, clicking on which displays the menu, and when the cell loses focus, the button disappears. Looking for how to do it on the documentation for a week, did not understand how to achieve this. The button I added, but how to make it appeared when focus a cell and its disappearance or hide when focus is lost, is unclear.
Steku
Re: Hide and show a button in a table cell on RichViewEdit
Post by Steku »
maybe you have to check for the current item to handle your visible/unvisible problem.
As a startting point you can have a look
here: http://www.trichview.com/help/idh_trich ... rentItemEx
or here: http://www.trichview.com/help/idh_trich ... titem.html
Greetings...
mohonko
Post by mohonko »
Thanks. This method i am used. How to make the button (rvsComponent) inserted into the table not move along with the text? How to set the cursor to enter text into a specific cell of the table in RichViewEdit?
I think that control insertion is not a good solution. As I understand, you do not need to modify document, you need just display a button.
I can suggest using a "smart popup". It is a button that can be shown next to the current item. It displays an icon and, optionally a triangle (useful if this button shows a menu) or ellipsis (useful if this button shows a dialog).
You can use this code in OnCaretMove to hide/show "smart popup":
procedure TForm3.RichViewEdit1CaretMove(Sender: TObject);
  // showing when the caret is in table cell
  RichViewEdit1.SmartPopupVisible := RichViewEdit1.InplaceEditor <> nil;
  // this cell can be get as:
  //  RichViewEdit1.TopLevelEditor.RVData.GetSourceRVData as TRVTableCellData
The only minus: this button is positioned next to the current item (bottom right corner by default; you can specify another corner); you cannot define its coordinates.
Additional info: http://www.trichview.com/help/idh_trich ... rties.html
mohonko
Post by mohonko »
Thank you very much. This mehod is good. How to disable the ability to change the external dimensions of the border with the mouse?
Do you mean disabling table resizing?
Exclude rvtoRowSizing and rvtoColSizing from table.Options
mohonko
Post by mohonko »
Thank you very much. :) :) :)
mohonko
Post by mohonko »
Is there any way to determine whether the cursor is on the left or right side of the table?
I am sorry for the delay.
There is a demo project that contains table and does not allow to move the caret outside of it:
http://www.trichview.com/forums/viewtop ... f=3&t=6382
Below is a code fragment from this demo showing how to implement this feature.
const WM_BACKTOTABLE = WM_USER+1;
  TfrmNoteList = class(TForm)
    Moving: Boolean;
    procedure WMBackToTable(var Msg: TMessage); message WM_BACKTOTABLE;
procedure TfrmNoteList.rveCaretMove(Sender: TObject);
  if not Visible or Moving then
  if (rve.InplaceEditor=nil) and not (rvstCreatingInplace in rve.RVData.State) then begin
    PostMessage(Handle, WM_BACKTOTABLE, 0, 0);
  if rve.InplaceEditor=nil then
  Cell := rve.TopLevelEditor.RVData.GetSourceRVData as TRVTableCellData;
  ItemNo := rve.TopLevelEditor.CurItemNo;
  Offs := rve.TopLevelEditor.OffsetInCurItem;
procedure TfrmNoteList.WMBackToTable(var Msg: TMessage);
var RVData: TCustomRVFormattedData;
  if not Visible or (rve.InplaceEditor<>nil) or (Cell=nil) then
  Moving := True;
    RVData := Cell.Edit as TCustomRVFormattedData;
    RVData.SetSelectionBounds(ItemNo, Offs, ItemNo, Offs);
    Moving := False;
rveCaretMove processes rve.OnCaretMove event. If the caret is outside of a table cell, it sends a message that invokes WMBackToTable procedure.
(we cannot move the caret directly inside OnCaretMove event, so we cannot directly call WMBackToTable, we need to use PostMessage)
Additionally, if we are inside a table cell, we storing this cell and the caret position in it.
In WMBackToTable, we starting editing cell and moving the caret to the last position in it. So, when the user tries to move the caret outside the table, it is immediately moves back.
This demo assumes that this table and cells inside it cannot be deleted. Otherwise, we need to intercept these operations and assign nil to Cell.
Sorry if the information above does not answer to your question. I believe your initial question was about not allowing placing the caret outside of the table.
As for this question:
if RichViewEdit1.InplaceEditor <> nil then
  exit; // the caret is inside a table
if not (RichViewEdit1.GetCurrentItem is TRVTableItemInfo) then
  exit; // the caret is not near the table
if RichViewEdit1.OffsetInCurItem = 0 then
  <before table>
  <after table>
Josepherny
Post by Josepherny »
Do you mean resizing images or resizing table columns and mouse?
