RVF to PDF : footer is vertical
NeeeeB
Post by NeeeeB »
I'm trying to generate a PDF from RVF (with llPDFLib as in your demo).
No matter what I do, my footer is always displayed vertically (in the PDF, in the ScaleRichView it is ok) :
(I can't post picture but instead of 'Test' at the bottom of the page, I get
T
e
s
t
This is what I do :
FileName:= IncludeTrailingPathDelimiter(FXMLFolder) + 'tmpText.rtf';
   SRve_Content.RichViewEdit.SaveRTF( FileName, False );
   RVReportHelper.RichView.LoadRTF( FileName );
I've also tried not to save footer in the RTF, and then add it when the RTF is loaded in the ReportHelper by doing this :
   Rvh_Footer.RichView.AddTextNL( 'test', GetHeaderFontIndex( 1 ), -1, 0 );
Same result, my footer is vertical...
Any idea what I'm doing wrong ? thx
Re: RVF to PDF : footer is vertical
Can you send me a sample project and document for testing?
richviewgmailcom
