Change the cursor for a table cell?
SmallDonkey
Post by SmallDonkey »
Hi, how can I change the cursor for a table cell? :roll: :roll: :roll:
08-03-2018 10-17-42.jpg (85.56 KiB) Viewed 13887 times
Re: Change the cursor for a table cell?
This cursor selects a row.
If you want to hide it, exclude rvtoRowSelect from table.Options (the same for columns and rvtoColSelect).
In the current version of TRichView, these cursors are hard-coded (read from resources).
SmallDonkey
Exactly what i needed :D :D :D
Thank you
Table.Options := Table.Options - [rvtoRowSelect];
Table.Options := Table.Options - [rvtoColSelect];
