I would like to try TRichView with the purpose of buying but the installer fails on Delphi 5 enterprise.
The error log
Error compiling C:\VCL\TRichViewTrialDelphi\TRichView\Trial\D5\RVPkgD5.dpk:
Borland Delphi Version 13.0 Copyright (c) 1983,99 Inprise Corporation
C:\DSoftNX\COMPON~1\DELPHI~3\02B5ED~1.99\Zlib\ZCONF.INC(33)
C:\DSoftNX\COMPON~1\DELPHI~3\02B5ED~1.99\Zlib\Zutil.pas(547)
C:\DSoftNX\COMPON~1\DELPHI~3\02B5ED~1.99\Zlib\Zlib.pas(523)
RVPkgD5.dpk(115) Fatal: Unit RVZip was compiled with a different version of Zlib.TCompressionStream
Error compiling C:\VCL\TRichViewTrialDelphi\TRichView\Trial\D5\RVDBPkgD5.dpk:
Error compiling C:\VCL\TRichViewTrialDelphi\RichViewActions\Source\RichViewActionsD5.dpk:
C:\VCL\TRichViewTrialDelphi\TRichView\Trial\D5\RVPkgD5.dpk(115) Fatal: Unit RVZip was compiled with a different version of Zlib.TCompressionStream
Error compiling C:\VCL\TRichViewTrialDelphi\RvHtmlImporter\Source\RvHtmlD5.dpk:
Error compiling C:\VCL\TRichViewTrialDelphi\RvXml\Source\RvXmlD5.dpk:
Error compiling C:\VCL\TRichViewTrialDelphi\ThirdParty\HunSpell\Source\RVHunSpellPkgD5.dpk:
Error compiling C:\VCL\TRichViewTrialDelphi\ThirdParty\ASpell\Source\RVASpellPkgD5.dpk:
Error compiling C:\VCL\TRichViewTrialDelphi\ScaleRichView\Trial\D5\SRVPkgD5.dpk:
Error compiling C:\VCL\TRichViewTrialDelphi\ScaleRichView\Trial\D5\DBSRVPkgD5.dpk:
Error compiling C:\VCL\TRichViewTrialDelphi\ReportWorkshop\Core\Trial\D5\ReportWorkshopD5.dpk:
Error compiling C:\VCL\TRichViewTrialDelphi\SRVControls\Source\SRVControlsD5.dpk:
TRichView Trial for Delphi 5 failed install
Re: TRichView Trial for Delphi 5 failed install
The TRichView trial version for Delphi 5 is compiled with the standard ZLib version included in Delphi 5.
As I can see, you have third-party ZLib implementation. While, most probably, the full TRichView version can be compiled with this custom version of ZLib, the trial cannot.
To install TRichView trial for Delphi 5, you need to uninstall third-party ZLib (from C:\DSoftNX\COMPON~1\DELPHI~3\02B5ED~1.99\Zlib) (including deleting its package (most probably, it is in <Delphi 5 Dir>\Projects\BPL) and removing "C:\DSoftNX\COMPON~1\DELPHI~3\02B5ED~1.99\Zlib" from Delphi library paths)
Thank you for your response and time Sergey.
We have a implementation of Delphi ZLib (version 0.2.99) with modifications (fundamental for our Delphi components).
Your TRichview is very good but for now doen't solve our problem.
Keep the good work.
Thanks again.
Keep the good work.
Thanks again.
