loading html to non-empty rve - possible?
elGringo
Post by elGringo »
good time, Sergey!
-dynamically composing my docs from different sources to rveMain
1-st loading from blob field
2-d loading html from other field and going to paste in to doc - for this going to create new rveAdditional- load html like this...
   RVAControlPanel.InitImportPictures(nil, nil);
          rve.OnImportPicture := RVAControlPanel.DoImportPicture;
          RVHTMLViewImporter.LoadFromFile(randomFilePath, rve);
          RVAControlPanel.DoneImportPictures;
          rve.OnImportPicture := nil;
                          //RvHtmlImporter.LoadHtml(randomFilePath);
          rve.FormatAll;
then going to select all and paste in rveMain
but this workaround seems to me not simple - is there any way to import some html content in document which is not empty to position of caret or next page?
Thanks in advance!
Re: loading html to non-empty rve - possible?
Call
HTMLViewer1.LoadFromFile
then
RVHtmlViewImporter1.AppendHtmlViewer
It adds HTML content to the end of TRichView.
elGringo
Post by elGringo »
Thank you very much!
elGringo
Post by elGringo »
final working decision is
(concerning to this http://www.trichview.com/forums/viewtopic.php?t=7138)
    SRichViewEditTemp := TSRichViewEdit.Create(Self);
    //copy content to another rve
      RVHTMLViewImporter.LoadFromFile(randomFilePath, SRichViewEditTemp.ActiveEditor);
      RVHTMLViewImporter.LoadFromClipboard(SRichViewEditTemp.ActiveEditor, HtmlViewer);
      RVHTMLViewImporter.AppendHtmlViewer(HtmlViewer, SRichViewEdit.ActiveEditor);
    //load back
      SRichViewEditTemp.Free();
elGringo
Post by elGringo »
Now problem with russian text encoding (((
Somewhere in this chain i should point that i use utf-8 but where?
Regards,
elGringo
Post by elGringo »
my full code to append html is
procedure TReportViewerForm.AppendHTMLContent(AHtml: string);
  tempDir: string;
  randomFilePath: string;
  clientTempDir: string;
  i: Integer;
  SRichViewEditTemp: TSRichViewEdit;
    tempDir := ExtractFilePath(Application.ExeName) + 'files\temp';
    TDirectory.CreateDirectory(tempDir);
    randomFilePath := tempDir + '\' + inttostr(Random(1000000)) + '.html';
    TFile.AppendAllText(randomFilePath, AHtml, TEncoding.UTF8);
    SRichViewEdit.ActiveEditor.OnImportPicture := RVAControlPanel.DoImportPicture;
    // appending content
    SRichViewEditTemp.ActiveEditor.OnImportPicture := RVAControlPanel.DoImportPicture;
    //load back
    SRichViewEdit.ActiveEditor.OnImportPicture := nil;
    SRichViewEdit.ActiveEditor.FormatAll();
    if TFile.Exists(randomFilePath) then
      TFile.Delete(randomFilePath);
elGringo
Post by elGringo »
or maybe srichview can change encoding after loading?
now a having
Интерпретация
Make HTMLViewer and SRichViewEdit visible. Is the text corrupted in HtmlViewer? If the text corrupted in SRichViewEdit?
And I do not understand, why do you call LoadFromClipboard?
elGringo
Post by elGringo »
clipboard 'cause if not - it erases all content before
the same as in this topic
ok, i will make them visible and test
LoadFromFile always erases all content before loading.
AppendHtmlViewer never erases.
elGringo
Post by elGringo »
result
https://yadi.sk/i/OKUzGmEO3QBiUT
in both cases
Русский текст
i just loaded...
procedure TReportViewerForm.LoadHTMLContent(AHtml: string);
  tempDir: string;
  i: Integer;
    RVHTMLViewImporter.LoadFromFile(randomFilePath, SRichViewEdit.ActiveEditor); // <<<
elGringo
Post by elGringo »
called like this
  rv := TReportViewerForm.Create(Self);
  rv.LoadHTMLContent('<b>Русский текст</b>');
  rv.Show;
As you can see, the garbage is already in THTMLViewer. It does not detected that your HTML has UTF-8 encoding.
Possible solutions
1) Specify UTF-8 encoding in HTML:
  LoadHTMLContent(
    '<head><meta http-equiv="Content-Type" content="text/html;charset=UTF-8"></head>'+
    '<b>Привет</b>');
2) Adding UTF-8 byte order mark in the beginning of the file (I did not try it, though)
3) Use TEncoding.Unicode instead of TEncoding.UTF8:
TFile.AppendAllText(randomFilePath, AHtml, TEncoding.Unicode);
Actually, you can implement this function without using files:
    HtmlViewer1.LoadFromString(AHtml);
    RVHTMLViewImporter1.AppendHtmlViewer(HtmlViewer1, SRichViewEdit1.ActiveEditor);
elGringo
Post by elGringo »
You are just brilliant !
used 3) and it worked an then used last advice of 2 strings without files and it also worked
but as for 3) not clear to me why when we change to TEncoding.Unicode it begins work? Because of initial text in UniCode?
elGringo
Post by elGringo »
also this variant
won't load pics as i understand?
