I am using RV version 14.6 / D7.
I have 100,000+ rvf documents stored in blobs which contain hyperlinks.
Now, i want to generate RTFs where hyperlinks are to be replaced by footnote number & relevant footnote matter (can be multiple para with tables).
Any ideas are welcome. Currently, i am planning to generate RTF files and parse all elements.
-Sam
Need advice from Team_RichView
Re: Need advice from Team_RichView
It would be much simpler to change TRichView content before saving RTF.
From where do you want to get footnote texts?
Thanks for providing the URL. I have now upgraded to RichView v17.
Now, i have managed to insert footnotes in Main document. However, i am facing trouble inserting footnotes inside tables. I am cycling through all items and getting ItemNo (inside cell) after which i want to insert footnote. However InsertItem() inserts at CurItemNo. Is there anything like "InsertItem_AfterItemNo" ?
PS : My footnote texts are RVF.
I attached a sample project converting hyperlinks to footnotes.
Before: After:
Before: After:
- LinksToNotes.zip
- (4.53 KiB) Downloaded 1296 times
Thanks Sergey,
I was not aware of "RVData.Items.InsertObject(i, s, Note)".
However, i managed with
table.cells[r,c].edit
setselectionbounds()
InsertItem()
etc.
Now i shall change my code to RVData.Items.InsertObject(i, s, Note)
Thanks.
InsertItem()
etc.
Thanks.
