Page breaks in HTML
elGringo
Page breaks in HTML
Post by elGringo »
Hello, Sergey!
Saving 2 pages to html, having following code below
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html><head><title></title>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<meta http-equiv="Content-Style-Type" content="text/css">
<style type="text/css"><!--
body {
  margin: 94px 57px 94px 132px;
  background-color: #ffffff;
/* ========== Text Styles ========== */
hr { color: #000000}
body, table, span.rvts0 /* Normal text */
 font-size: 10pt;
 font-family: 'Arial', 'Helvetica', sans-serif;
 font-style: normal;
 font-weight: normal;
 color: #000000;
 text-decoration: none;
span.rvts1 /* Heading */
 font-weight: bold;
 color: #0000ff;
span.rvts2 /* Subheading */
 font-weight: bold;
 color: #000080;
span.rvts3 /* Keywords */
 font-style: italic;
 color: #800000;
a.rvts4, span.rvts4 /* Jump 1 */
 color: #008000;
 text-decoration: underline;
a.rvts5, span.rvts5 /* Jump 2 */
 color: #008000;
span.rvts6
 color: #000000;
span.rvts7
 font-size: 22pt;
 font-family: 'calibri';
 color: #000000;
span.rvts8
 font-size: 14pt;
 color: #000000;
span.rvts9
 font-size: 14pt;
 color: #969696;
span.rvts10
 color: #808080;
span.rvts11
 font-size: 16pt;
 color: #333333;
span.rvts12
 color: #333333;
/* ========== Para Styles ========== */
p,ul,ol /* Paragraph Style */
 text-align: left;
 text-indent: 0px;
 padding: 0px 0px 0px 0px;
 margin: 0px 0px 0px 0px;
.rvps1 /* Centered */
 text-align: center;
--></style>
</head>
<body>
<p><span class=rvts6><br></span></p>
<p class=rvps1><span class=rvts6><br></span></p>
<p class=rvps1><span class=rvts7>Отчет по элементу события пользователя</span></p>
<p class=rvps1><span class=rvts8><br></span></p>
<p class=rvps1><span class=rvts11>{{0}}</span></p>
<p class=rvps1><span class=rvts9><br></span></p>
<p class=rvps1><span class=rvts11>{{1}}</span></p>
<p class=rvps1><span class=rvts12>{{2}}</span></p>
<p class=rvps1 style="page-break-before: always;"><span class=rvts12>123</span></p>
<p class=rvps1><span class=rvts10><br></span></p>
</body></html>
it has link to css style style="page-break-before: always;" but no style in code...
so when loading back to srichview - all content on one page - could you advice something?
save html
procedure TReportTemplatesConstructor.SaveHTMLContent();
  with qSelectReportTemplate do
      connection := MainModule.FDConnection;
      CachedUpdates := true;
      Params.ParamValues['id'] := FReportTemplateID;
      Disconnect();
      Open();
      trWrite.Connection := MainModule.FDConnection;
      trWrite.StartTransaction();
      Edit();
      FieldByName('htmlContentHeader').AsString := getHtmlFromRVE(SRichViewEdit.RVHeader);
      FieldByName('htmlContentBody').AsString := getHtmlFromRVE(SRichViewEdit.RichViewEdit);
      FieldByName('htmlContentFooter').AsString := getHtmlFromRVE(SRichViewEdit.RVFooter);
      if ApplyUpdates <> 0 then
        raise Exception.Create(RowError.Message);
      trWrite.Commit();
      //Close();
    except
      on E: Exception do
        raise Exception.Create('Error Message ' + E.Message);
load html
procedure TReportViewerForm.LoadHTMLContent(AHtml: string);
  tempDir: string;
  randomFilePath: string;
  clientTempDir: string;
  i: Integer;
    tempDir := ExtractFilePath(Application.ExeName) + 'files\temp';
    TDirectory.CreateDirectory(tempDir);
    randomFilePath := tempDir + '\' + inttostr(Random(1000000)) + '.html';
    TFile.AppendAllText(randomFilePath, AHtml, TEncoding.UTF8);
    RVAControlPanel.InitImportPictures(nil, nil);
    SRichViewEdit.ActiveEditor.OnImportPicture := RVAControlPanel.DoImportPicture;
    RVHTMLViewImporter.LoadFromFile(randomFilePath, SRichViewEdit.ActiveEditor);
    RVAControlPanel.DoneImportPictures;
    SRichViewEdit.ActiveEditor.OnImportPicture := nil;
    SRichViewEdit.ActiveEditor.FormatAll();
    if TFile.Exists(randomFilePath) then
      TFile.Delete(randomFilePath);
 // normalizing table borders
  for i := 0 to SRichViewEdit.ActiveEditor.ItemCount - 1 do
    if ((SRichViewEdit.ActiveEditor.GetItem(i).StyleNo = -60)) then
      SRichViewEdit.ActiveEditor.SetItemTag(i, i.ToString());
      FTableListSL.Add(i.ToString());
      NormalizeTableBorders(i);
Questions
1) how to split correctly on pages when save load from html?
2) how to save header and footer of each page and then load it? For the moment i just doing sometging like this
but not sure it is correct
Thanks in advance!
Re: Page breaks in HTML
TRvHtmlViewImporter does not read page break properties from HTML.
I checked, it looks like THTMLViewer supports them, so import is possible. I'll try to implement it in one of future updates.
I do not understand your question about headers and footers. Do you save them as separate HTML documents?
In older version of ScaleRichView, a header and a footer were really always stored in RVHeader and RVFooter.
In the new version, SRV.RVHeader/RVFooter contains header/footer only if a header/footer is being edited. Otherwise, they are in SRV.SubDocuments.
It is possible to use SubDocuments[].SaveHTMLToStreamEx, however, there are some complication, so I can suggest this code:
      SRichViewEdit.CanUpdate := False;
      SRichViewEdit.StartEditing(srvrveHeader);
      SRichViewEdit.StartEditing(srvrveFooter);
      SRichViewEdit.StartEditing(srvrveMain);
      SRichViewEdit.CanUpdate := True;
elGringo
Post by elGringo »
thank you, but how can i use THTMLViewer to import HTML to sRichView? Could you give a small piece of code?
Regards, Stanislav
I just need to show report created in SrichViewEdit with pages...
If you use RichViewActions, you can use TRvHtmlViewImporter without writing any code (some code is needed only to download external CSS files, it is described in this topic: http://www.trichview.com/forums/viewtop ... f=5&t=8784 , but it is available only for registered users).
Without RichViewActions:
  if OpenDialog1.Execute then
    HTMLViewer1.LoadFromFile(OpenDialog1.FileName);
    RVHTMLViewImporter1.ImportHtmlViewer(HTMLViewer1, SRichViewEdit1.RichViewEdit,
      ExtractFilePath(OpenDialog1.FileName));
    SRichViewEdit1.RichViewEdit.RVData.NormalizeDocument(0, True);
    SRichViewEdit1.Format;
If you want to download remote images, you need to process SRichViewEdit1.OnImportPicture. RichViewActions do it automatically, if RVAControlPanel.DownloadInterface is assigned.
elGringo
Post by elGringo »
Sergey, thank you! I will try !
