Just upgraded to 17.0.1 and get compiler error
jimmaguire
Post by jimmaguire »
This is a big problem. I get this error: "undeclared identifier TCustomRVFormattedData".
I'm using Delphi Tokyo. Had previously installed in Delphi Seattle. The actions demo compiles fine. I copied its uses to mine to see if that was the issue.
Help! :(
Re: Just upgraded to 17.0.1 and get compiler error
Do you get this report in your code? Add CRVFData in "uses".
