Error "Division by zero" on loading rvf file
saeid2016
Post by saeid2016 »
When I load my attached rvf file by ScaleRichView it gives error: "Division by zero" in ApplyJustify procedure of CRVFData. I use your ActionTest demo.
But when I load it with RichViewEdit component, It loads without any problem.
The attached rvf file paragraph alignment is rvajustify, If I change it to rvaright the ScaleRichView loads it successfully like RichViewEdit.
I attached the used font too.
IRANSans.rar
(53.71 KiB) Downloaded 2276 times
rvftest.rvf
(16.25 KiB) Downloaded 2303 times
Re: Error "Division by zero" on loading rvf file
I confirm the problem.
Quick fix (in v17.0.1): open CRVFData.pas, change the line 4608 from
        if (DX <> 0) and (CurDItem.SpaceCount <> 0) then
to
        if (DX <> 0) and (CurDItem.SpaceCount <> 0) and (TotalExtraSpace > 0) then
This fix will be included in the next update.
Fixed in v17.0.2
