How to control the caret position after pasting content
wolf1860
Post by wolf1860 »
I want to adjust the pictures valign property after the paste action, the problem is after I finished the adjusting ,the caret position is set to the pasted content beginning automatic, not at the end of the pasted content normally.How to fix this?
this is my code:
private
  pasted:Boolean;
procedure TfrmRvfEditorMain.SRichViewEdit1Paste(Sender: TCustomRichViewEdit; var DoDefault: Boolean);
  pasted := True;
  DoDefault:=True;
procedure TfrmRvfEditorMain.SRichViewEdit1Change(Sender: TObject);
  rve: TRichViewEdit;
  rve := TSRichViewEdit(Sender).RichViewEdit;
  if pasted then
    //adjust the valign
    RVAlignImages(rve);
    pasted := False;
procedure TfrmRvfEditorMain.RVAlignImages(rve: TRichViewEdit; iAlign: TRVVAlign = rvvaAbsMiddle);
  i: Integer;
  StyleNo: Integer;
  if rve = nil then
  for i := 0 to rve.ItemCount - 1 do
    StyleNo := rve.GetItemStyle(i);
    if StyleNo = rvsPicture then
      rve.SetItemVAlign(i, iAlign);
  rve.Format;
Re: How to control the caret position after pasting content
You can store the caret position using RVGetSelection, and restore it using RVSetSelection (unit RVLinear).
But I can suggest another solution. You can adjust VALign of images in OnItemAction event, ItemAction = rviaInserted, if pasted = True.
wolf1860
Post by wolf1860 »
It works perfect good by ur solution, thank u!
