Mouse wheel scroll does not work in Win7
I tested this on couple of PC, the mouse wheel worked perfect in Win10,but did not work in Win7,I changed 3 PC (win7).
Re: Mouse wheel scroll does not work in Win7
What version of Delphi do you use to compile applications?
Delphi 10.2
I confirm the problem: no mouse wheel scrolling in TSRichViewEdit in Windows versions prior to 10, for applications compiled in RAD Studio 10.1 and 10.2
It will be fixed in the next update (I'll try to upload it later today)
Thanks a lot:) I'm waiting for the new version.
Sorry for the delay, it is uploaded today (for registered users)
Downloaded latest version of TSRichViewEdit. Now modules compiled on Windows 10 machine with RAD Studio 10.2 work fine on Windows 7 or prior but on Windows 10 scrolling does not work!
Make sure that you completely recompiled your application (Project | Build All Project).
If the problem still persists, I ask you to do some tests.
The first of them. Please open SclRView.pas, find TSRichViewEdit.DoMouseWheel.
It must be:
Is it correct? Compile your application with debug info. Put a breakpoint at the beginning of this method. Is it called when you scroll with a mouse wheel?
PS: please pay attention: in older versions of Windows, mouse wheels scrolls the focused control. In Windows 10, mouse wheels scrolls the control below the mouse pointer.
It must be:
function TSRichViewEdit.DoMouseWheel(Shift: TShiftState; WheelDelta: Integer;
MousePos: TPoint): Boolean;
Result := inherited DoMouseWheel(Shift, WheelDelta, MousePos);
if RVWIN10 and not Result then
HookMouseWheelEvent(Self, Shift, WheelDelta, MousePos, Result);
Thank you for support. The problem is still persists. HookMouseWheelEvent in TSRichViewEdit.DoMouseWheel event is never called because variable RVWIN10 is false. In addition the vi.dwMajorVersion == 6 in RVUni.RVCheckNT but we have Windows 10 Pro x64.
If dwMajorVersion = 6, this means that your application is not marked as Win10-compatible.
I thought that the difference in mouse wheel processing in applications compiled in 10.1 and 10.2 is because they are marked as Win10-compatible (in their manifest). Currently, I have no other ideas.
If you do not have special reasons for using a custom manifest, change in Project | Options, Application, Manifest file = Auto Generate.
in my case it doesn't work either in our application. It does work in sample ActionTest software. The thing is that alhough I am using Windows 10 64 bit Slovenian and I have to use custom manifest due to some reasons and I deliberately have no compliance with Windows 10 in manifest file. I did slight investigation as our software does recognize different windows, from XP to 10, how You do it. You have to modify a bit RVUni.pas as so:
Add in line 186:
Substiute the procedure with this code:
So far as I have been checking around our customers (n*100) works okay. If anyone else around has similar problems, please do try and confirm correction.
Best regards,
Goran
Add in line 186:
function RtlGetVersion (var lpVersionInformation: TOSVERSIONINFOEXW): DWORD; stdcall; // Windows 2000 and later
external 'ntdll.dll' name 'RtlGetVersion';
procedure RVCheckNT;
//vi: TOSVersionInfo; //<---- old, not in use in WIn10
vi :_OSVersionInfoExW;
vi.dwOSVersionInfoSize := sizeof(vi);
//GetVersionEx(vi); //<--- substituted with line below
RtlGetVersion(vi);
RVNT := vi.dwPlatformId = VER_PLATFORM_WIN32_NT;
RVVista := RVNT and (vi.dwMajorVersion >= 6);
RVWin10 := RVNT and (vi.dwMajorVersion >= 10);
if not RVNT then
RVFORMATCANVASFACTOR := 10;
RVFORMATCANVASRESOLUTION := 96 * RVFORMATCANVASFACTOR;
if RVNT then
RVDI_GETDRAGIMAGE := RegisterWindowMessage('ShellGetDragImage')
RVDI_GETDRAGIMAGE := 0;
Best regards,
Goran
I'll include your changes in the next update.
But since the current solution works with standard Delphi manifests, I'll not activate these changed by default.
They will be activated if you specify the compiler $define RVKERNELWINVERCHECK when compiling your project.
