Encoding, WTF
elGringo
Encoding, WTF
Post by elGringo »
trying to save in HTML like this
rve.SaveHTMLToStreamEx(ss,'','','','','','', [rvsoUTF8,rvsoUseCheckpointsNames, rvsoUseItemImageFileNames]);
english text ok, but russian, for example word "Привет" is saved like
<p>ПРивет</p>
WTF?
Regards,
Re: Encoding, WTF
This is 'ПРивет' in UTF-8 encoding. It must be displayed correctly in browsers.
elGringo
Re: Encoding, WTF
Post by elGringo »
:wink: Ok! Thanks!
Just i do component that is switching from rve to htmlMemo and back, so when i switch to html, in spite of <p>Привет</p> it is visible UTF - no way to fix it?
Re: Encoding, WTF
How do you switch to htmlMemo? Please post code, I'll correct it.
elGringo
Re: Encoding, WTF
Post by elGringo »
there is some button, on click it saves to db, makes invisible rve or memo (depends on what is visible now), then loading back to memo and rve
save in db
procedure TTestsRvePanel.UpdateHTMLContenInDB;
var htmlContent:string;
    ss:TStringStream;
 if rve.Visible then begin
     ss:=TStringStream.Create;
      ss.Position:=0;
      rve.DeleteUnusedStyles(True, True, True);
      rve.ClearUndo;
      htmlContent:=ss.DataString;
     ss.Free;
 end else if Memo.Visible then htmlContent:=memo.Lines.Text;
 //update HTML content in descendants
 if Assigned(FOnUpdateHTMLContent) then FOnUpdateHTMLContent(htmlContent);
loading
procedure TTestsRvePanelQuestion.LoadHTMLContentFromDB();
var myOwner:TTestsMF;
    tempDir: string;
    randomFilePath: string;
    qSelectHTMLContent:TFDquery;
    clientTempDir: string;
    //RVHTMLViewImporter:TRVHTMLViewImporter;
     addEditForm:TTestsAddEditForm;
 myOwner:=(Self.Owner.Owner.Owner as TTestsMF);
 addEditForm:=(Self.Owner as TTestsAddEditForm);
 qSelectHTMLContent:=TFDquery.Create(Self);
  with qSelectHTMLContent do begin
    Connection:=myOwner.FDConnection_ExternalConnect;
    qSelectHTMLContent.SQL.Text:='SELECT * FROM database.testquestions where id=:id';
    Params.ParamValues['id']:=addEditForm.questionID;//  FQuestionID;
    Disconnect(); Open;
    Memo.Lines.Text:=FieldByName('htmlContent').AsString;
    Close;
           //filling rve from  temp file
               tempDir:=ExtractFilePath(Application.ExeName)+'files\temp';
               TDirectory.CreateDirectory(tempDir);
               randomFilePath:=tempDir+'\'+ inttostr(Random(1000000))+'.html';
               Memo.Lines.SaveToFile(randomFilePath);
                RVAControlPanel.InitImportPictures(nil, nil);
                rve.OnImportPicture := RVAControlPanel.DoImportPicture;
                RVHTMLViewImporter.LoadFromFile(randomFilePath,rve);
                RVAControlPanel.DoneImportPictures;
                rve.OnImportPicture := nil;
                //RvHtmlImporter.LoadHtml(randomFilePath);
                rve.FormatAll;
            if TFile.Exists(randomFilePath) then
            TFile.Delete(randomFilePath);
 qSelectHTMLContent.Free;
Re: Encoding, WTF
Try creating TStringStream with UTF=8 encoding:
ss :=  TStringStream.Create('', TEncoding.UTF8)
elGringo
Re: Encoding, WTF
Post by elGringo »
Thanks, but didn't help. Nevermind for the moment.
