Preview, default pinter and two printers in system
Post by + 1 »
Hi all.
I have two printers in system, in one (default) size of papers is A4, in second width of paper is 80 mm.
I need to print the document on the second printer.
If I open the preview, the paper size A4 is displayed there.
How to change the target printer on the preview?
Re: Preview, default pinter and two printers in system
TRichView uses setting of the current printer.
You can change printer by assigning Printer.PrinterIndex, where Printer is defined in the Printers unit.
+ 1
Post by + 1 »
Серега, извини, вчера с пивом перебор вышел.
Дай код, пожалуйста.
What code do you need?
uses Printers;
Printer.PrinterIndex := 0; // switching to printer having the name Printer.Printers[0]
Printer.PrinterIndex := 1; // switching to printer having the name Printer.Printers[1]
If preview is already displayed, you need to call RVPrint.FormatPages after changing PrinterIndex.
