can I somehow fix a behavior when spaces between lines are changing after tab key is pressed? (Only first tab on the line).
Please see example below. It has been recorded on ActionTestUni demo.
Thank you for your answer.
ScaleRichViewEdit - line spacing are changed after tab
- TabAndLineSpacing.rvf
- (4.99 KiB) Downloaded 2219 times
Re: ScaleRichViewEdit - line spacing are changed after tab
I confirm the problem. A difference may be 1 pixel due to rounding errors. It will be fixed in the next update.
Thank you, I'm glad it is solvable.
Yes, it is solvable.
In the current version, text is measured on a high-resolution canvas, while tab height is still measured on a screen canvas.
I changed, now the both of them are measure on a high-resolution canvas, and the results are identical.
Hi Sergey,When is the new release coming out?
Later in this week.
