Snapshot from an axis ip camera stream doesn't work
I have a registered version of RVMedia. I can connect to both USB webcams and axis image server streams as expected. Both streams are visible in the viewer component. However, I can only take snapshots from USB webcams. GetBitmap will also only work with USB webcams. I do not want to record at the full frame rate. Is there some othe way to extract frames periodically from an axis ip camera stream?
Re: Snapshot from an axis ip camera stream doesn't work
Do you have a viewer connected to this camera? If video from camera is not displayed or is not sent further, the component does not decode frames.
A workaround is assigning empty event handler for TRVCamera.OnGetImage event
Thanks for your quick response. I do have a viewer connected and it works correctly for both the USB webcams and the axis image server. Getsnapshot provides excactly the functionality I need but I'll look at implementing something based on the new image event.
Snapshots will be ok in the next version that we will upload soon. Until then, please use this event.
Snapshot no work with XE7 y RVmedia, i test the follow metod, please your help.
procedure TVerPano.RVCamera2GetImage(Sender: TObject; img: TRVMBitmap);
procedure TVerPano.RVCamera2SearchComplete(Sender: TObject; Status: Integer);
RVCamera2.PlayVideoStream;
procedure TVerPano.SpeedButton1Click(Sender: TObject);
Img: TRVImageWrapper;
Img := RVCamera2.GetSnapShot;
pbSnapShot.Canvas.Draw(0, 0, Img.Bitmap.GetBitmap);
Img.Free;
{ /// test with JVDimage no work
JvDbImage1.Picture.Graphic := Img.Bitmap.GetBitmap;
Img.Free;
Img.Free;
Img.Free;
Please re-test with RVMedia 6.0. It was uploaded today (and it's not yet announced).
You can re-run RVMedia installer, it can check for updates and download the new version.
