Load RVF with footer and save to RTF
arkinform
Post by arkinform »
Hello!
We use TRichView for own simple report processing. We make and save RVF templates. When user execute template, we load RVF, replace some variables and save to RTF for opening with MS Word or LibreOffice. It works fine, but we have one problem: RVF with footer is loaded without it. We can set footer manualy (commented lines) and it works, but how to get footer from RVF and why procedure LoadRVF does not load footers?
RichView.RTFReadProperties.ReadDocParameters := True;
RichView.RTFReadProperties.ParaStyleMode     := rvrsAddIfNeeded;
RichView.RTFReadProperties.TextStyleMode     := rvrsAddIfNeeded;
RichView.RTFReadProperties.UnicodeMode       := rvruOnlyUnicode;
RichView.RVFOptions := [rvfoLoadDocProperties, rvfoSaveDocProperties,
      rvfoSavePicturesBody, rvfoSaveControlsBody,
      rvfoIgnoreUnknownPicFmt, rvfoIgnoreUnknownCtrls,
      rvfoConvUnknownStylesToZero, rvfoConvLargeImageIdxToZero,
      rvfoSaveBinary, rvfoSaveBack, rvfoLoadBack,
      rvfoSaveTextStyles, rvfoSaveParaStyles, rvfoSaveLayout,
      rvfoLoadLayout];
RichView.RTFOptions :=
      [rvrtfDuplicateUnicode, rvrtfSaveEMFAsWMF,
       rvrtfSaveJpegAsJpeg, rvrtfSavePngAsPng,
       rvrtfSaveDocParameters, rvrtfSaveHeaderFooter,
       rvrtfSavePicturesBinary];
RichView.LoadRVF('c:\temp\template.rvf');
// RichFooter.LoadText('c:\temp\footer.txt', 0, 0, True);
// RichView.RTFReadProperties.SetFooter(RichFooter.RVData);
RichView.SaveRTF('c:\temp\result.rtf', False);
template.zip
Template example
(22.5 KiB) Downloaded 1778 times
Re: Load RVF with footer and save to RTF
Automatic loading of headers and footers from RVF is implemented only in ScaleRichView.
For TRichView, it's not documented but possible.
Call (before saving and loading):
with RichView.GetExtraDocuments do
  Clear;
  AddObject('header', RichHeader.RVData);
  AddObject('footer', RichFooter.RVData);
  // you can also specify first page and even pages header/footers using identifiers: headerf, footerf, headerr, footerr.
arkinform
Post by arkinform »
Sorry for answer with very long delay.
I have tried your code. In this case I see footer in output RTF document, but I lose some formatting from the original RVF document (bold, alignment and etc). And more, when I remove rvfoConvUnknownStylesToZero from FRichView.RVFOptions, the output RTF document does not contain some text at all. Without processing footer (comment block with FRichView.RVData.ExtraDocumentsList and SetFooter) LoadRVF --> SaveRTF works fine.
  FRichView: TRichView;
  FRichViewHeader: TRichView;
  FRichViewFooter: TRichView;
  FRichStyle        : TRVStyle;
  FRichStyle2       : TRVStyle;
  FRichStyle3       : TRVStyle;
  FRichView         := TRichView.Create(nil);
  FRichViewHeader   := TRichView.Create(nil);
  FRichViewFooter   := TRichView.Create(nil);
  FRichStyle        := TRVStyle.Create(nil);
  FRichStyle2       := TRVStyle.Create(nil);
  FRichStyle3       := TRVStyle.Create(nil);
    FRichView.Visible      := False;
    FRichView.Parent       := Self;
    FRichView.Style        := FRichStyle;
    FRichViewHeader.Visible      := False;
    FRichViewHeader.Parent       := Self;
    FRichViewHeader.Style        := FRichStyle;
    FRichViewFooter.Visible      := False;
    FRichViewFooter.Parent       := Self;
    FRichViewFooter.Style        := FRichStyle;
    FRichView.RTFReadProperties.TextStyleMode := rvrsAddIfNeeded;
    FRichView.RTFReadProperties.ParaStyleMode := rvrsAddIfNeeded;
    FRichView.RTFReadProperties.UnicodeMode := rvruOnlyUnicode;
    FRichViewHeader.RTFOptions := FRichView.RTFOptions;
    FRichViewHeader.RTFReadProperties.TextStyleMode := rvrsAddIfNeeded;
    FRichViewHeader.RTFReadProperties.ParaStyleMode := rvrsAddIfNeeded;
    FRichViewHeader.RTFReadProperties.UnicodeMode := rvruOnlyUnicode;
    FRichViewFooter.RTFOptions := FRichView.RTFOptions;
    FRichViewFooter.RTFReadProperties.TextStyleMode := rvrsAddIfNeeded;
    FRichViewFooter.RTFReadProperties.ParaStyleMode := rvrsAddIfNeeded;
    FRichViewFooter.RTFReadProperties.UnicodeMode := rvruOnlyUnicode;
    FRichView.RVFOptions := [rvfoLoadDocProperties, rvfoSaveDocProperties,
          rvfoLoadLayout];
    FRichView.RTFOptions :=
    with FRichView.RVData.ExtraDocumentsList do
      Clear;
      AddObject('header', FRichViewHeader.RVData);
      AddObject('footer', FRichViewFooter.RVData);
    FRichView.LoadRVF('c:\temp\template.rvf');
    FRichView.RTFReadProperties.SetFooter(FRichViewFooter.RVData);
    FRichView.SaveRTF('c:\temp\result.rtf', False);
    FRichStyle.Free;
    FRichStyle2.Free;
    FRichStyle3.Free;
    FRichViewHeader.Free;
    FRichViewFooter.Free;
    FRichView.Free;
1) You create three RVStyles, but assign the same RVStyle (FRichStyle) to all 3 controls. Assign different RVStyles, and the main problem will be fixed.
2) Assign the same RVFOptions to FRichViewHeader and FRichViewFooter, otherwise RTF will have incorrect formatting in headers and footers.
3) Optional. Your RVF file uses StyleTemplates (named styles). If you want to keep them in RTF, add:
    FRichView.UseStyleTemplates := True;
    FRichViewHeader.UseStyleTemplates := True;
    FRichViewFooter.UseStyleTemplates := True;
    FRichStyle2.MainRVStyle := FRichStyle;
    FRichStyle3.MainRVStyle := FRichStyle;
(I assume that FRichStyle2 is assigned to FRichViewHeader.Style, FRichStyle3 is assigned to FRichViewFooter.Style)
arkinform
Post by arkinform »
Thank you, works fine
