Bullet lists in Right-to-left languages
Hanno
Post by Hanno »
If I create a simple bullet list and switch the direction to right-to-left it looks good in the editor, but when I save to html, although the "direction: rtl" is correct, the bullets are not visible. They are off the right side of the screen. I can compensate by setting a paragraph right indent of about 20, but I don't think this is how it should be done. When I go into the "Customize" bullet list screen, there is only a Left Indent in the Text Position section. Should there be a "Right Indent" for right-to-left languages?
Added in to-do list
Hanno
Post by Hanno »
OK, thanks, if you could please let me know when this is ready I would appreciate it. I have a customer chasing me :-(
