[How to] How to print 2 documents in one printing job, etc.
:?: How to print more than one document in one printing job?
:?: How to print two documents on one page?
Printer.BeginDoc;
RVPrint.StartAt := 0;
RVPrint.TransparentBackground := True;
RVPrint.AssignSource(RichView1);
RVPrint.FormatPages(rvdoALL);
RVPrint.ContinuousPrint;
RVPrint.StartAt := RVPrint.EndAt;
{ // not necessary in the latest verison of TRichView
if RVPrint.rv.Height-RVPrint.StartAt<some safe value then
  Printer.NewPage;
RVPrint.AssignSource(RichView2);
Printer.EndDoc;
This code uses undocumented properties StartAt and EndAt. I think they are self explanatory. It also uses ContinuousPrint method. It's like Print method, but does not start and end a printing job.
Last edited by Sergey Tkachenko on Thu Oct 04, 2007 10:09 am, edited 2 times in total.
:?: How to change paper orientation?
Change Printer.Orientation to poLandscape (or poPortrait) before calling RVPrint.FormatPages.
(Printer is defined in the Printers unit)
Last edited by Sergey Tkachenko on Thu Sep 08, 2005 7:48 pm, edited 1 time in total.
:?: How to mix portrait and landscape orientation?
You need to separate your document in two (or more) parts - one with portrait orientation, and one with landscape orientation.
Printer.BeginDoc;
Printer.Orientation := ...;
RVPrint1.ContinuousPrint;
Printer.NewPage;
RVPrint2.ContinuousPrint;
Printer.EndDoc;
:?: How to print the chosen pages, for example 1, 3, 4, 5, 23?
procedure PrintSomePages(const Title: String;
  RVPrint: TRVPrint; const Pages: array of Integer);
var i: Integer;
  Printer.Title := Title;
  Printer.BeginDoc;
  for i := Low(Pages) to High(Pages) do begin
    if i<>Low(Pages) then
      Printer.NewPage;
    RVPrint.DrawPage(Pages[i], Printer.Canvas,False);
  Printer.EndDoc;
Test:
PrintSomePages('Test', RVPrint1, [1, 3, 4, 5, 23]);
:?: How to print only odd or even pages?
Update: in TRichView 17, new optional parameters were added in TRVPrint.PrintPages: PageSet and Ascending. They allow printing all/odd/even pages in normal and reverse directions. The code below still works, but is not needed any more.
procedure PrintOddOrEvenPages(const Title: String;
  RVPrint: TRVPrint; Odd: Boolean);
var i: Integer;
  Printer.BeginDoc;
  for i := 1 to RVPrint.PagesCount do
    if (Odd and (i mod 2=1)) or (not Odd and (i mod 2=0)) then begin
      if i>2 then
        Printer.NewPage;
      RVPrint.DrawPage(i, Printer.Canvas,False);
  Printer.EndDoc;
Updates:
2018-Apr-9: changes for compatibility with TRichView 17
Last edited by Sergey Tkachenko on Sat Aug 19, 2006 1:46 pm, edited 1 time in total.
:?: How to print without background?
Set RVPrint.TransparentBackground = True. Background color will not be painted.
Call RVPrint.rv.BackgroundBitmap := nil after calling RVPrint.AssignSource. Background bitmap will not be printed.
:?: How to print the selected fragment
There are no functions for printing the selection.
The only way to do it is to copy it to the separate (hidden) RichView and to print it.
var Stream: TMemoryStream;
// copying the selection
  rvSource.SaveRVFToStream(Stream, True);
  Stream.Position := 0;
  rvHidden.LoadRVFFromStream(Stream);
  Stream.Free;
// printing
RVPrint1.AssignSource(RVHidden);
RVPrint1.FormatPages(rvdoAll);
RVPrint1.Print('Selection', 1, False);
Benoit B.
Post by Benoit B. »
Sergey Tkachenko wrote::?: How to mix portrait and landscape orientation?
Printer.BeginDoc;
Printer.NewPage;
Printer.EndDoc;
How to do that with Borland C++ Builder 6 please ?
Almost exactly the same:
Printer()->BeginDoc();
Printer()->Orientation = ...;
RVPrint1->ContinuousPrint();
Printer()->NewPage();
RVPrint2->ContinuousPrint();
Printer()->EndDoc();
where poPortrait or poLandscape must be used instead of ...
The code above assumes that RVPrint1 and RVPrint2 were already formatted (in the proper page orientation).
If not, the full code will be:
RVPrint1->FormatPages(TRVDisplayOptions());
RVPrint2->FormatPages(TRVDisplayOptions());
Benoit B.
Post by Benoit B. »
Thanks for your help.
Now it works ! :D
YannickM
Post by YannickM »
Is there a way to have pages in different orientations in the print preview aswell ?
Assuming that you have 2 documents in 2 RVPrints, one formatted in portrait and one in landscape orientation, you can display preview with different orientations. RVPrintPreview displays only one page at once, so assing the proper RVPrint to RVPrintPreview.RVPrint property when moving to another page. You also need to assign the proper value to Printer.Orientation when switching pages.
YannickM
Post by YannickM »
Thanks for the quick response.
I am working with 1 document, and with your suggestion to use 2 RVPrints, I succeeded in mixing portrait and landscape in the print preview.
The only problem I am having now however, is since the RichViewEdit box only allows a document to have an orientation, and not each page independantly, that all the pages have the same size (the same number of lines of text). I cannot detect pagenumbers correctly.
Any ideas ?
Sorry, I do not understand your question.
Do you format 2 different TRichViews, one in portrait and one in landscape orientation?
YannickM
Post by YannickM »
No, I have 1 TRichView and I am trying to get portrait and landscape orientation mixed on a page-to-page basis throughout the document. Similar to what you can do in a text editor like Word.
Is this even possible ?
No, I suggest to format parts of documents having different orientation in different RichViews
