ip camera wiev help
ip camera wiev help
Friends,
I have a ip camera, I want to connect to it and watch it?
If you give an example, I am happy.
Thank you
RVCamera1.Parameters.Alias := 'Foscam';
RVCamera1.CameraHost := '192.168.1.245';
RVCamera1.CameraPort := 80;
RVCamera1.UserName := 'admin';
RVCamera1.UserPassword := '12345';
RVCamera1.SearchCamera;
IP camera model : DP-12CD1010-I
HTTP Port 80
RTSP Port 554
HTTPS Port 443
Server Port 8000
Thank you
HTTP Port 80
RTSP Port 554
HTTPS Port 443
Server Port 8000
Re: ip camera wiev help
If this camera is RTSP / H.264 camera, you need
1) Assign RVCamera1.VideoFormat := rvvfH264 (if it is equal to rvvfMJPEG, SearchCamera searches only for MJPEG streams)
2) Make sure that FFmpeg DLLs are available
PS: If you know that the camera is Foscam camera, you can speed up searching by specifying the parameter:
RVCamera1.SearchCamera([rvctFoscam]).
As for CameraPort, you can leave it = 0, or specify 80, as you did.
ip camera DP-12CD1010-I
demo 8Cams
The code is as follows
Thank you
// ----- Camera 1 -----
RVCamera1.CameraPort :=554;
demo 8Cams
Thank you
So, does it work?
If not, assign
RVCamera1.CameraPort := 0;
And make sure that FFmpeg library is available (the demo 8Cams shows when it can find FFmpeg)
If not, assign
No no it does not work I can not connect to ip camer somehow.
Could you give an example?
For the both examples below, check RVCamera1.IsSupportedFFMPEG.
If it returns False, video from H.264 cameras cannot be displayed, so make sure that everything is ok.
FFmpeg can be taken, for example, from here: http://www.trichview.com/forums/viewtop ... =17&t=6880
(copy 32-bit DLLs to the application folder)
Example 1, wait mode
SearchCamera returns when search is finished. The applications freezes while searching.
Example 1, no-wait mode
SearchCamera returns immediately; when search is finished, OnSearchComplete occurs.
OnSearchComplete event:
RVCamera1.CommandMode := rvsmWait;
RVCamera1.VideoFormat := rvvfH264 ;
if RVCamera1.SearchCamera then
RVCamera1.PlayVideoStream
// show error
RVCamera1.CommandMode := rvsmNoWait;
RVCamera1.PlayVideoStream;
procedure TfrmMain.RVCamera1SearchComplete(Sender: TObject; Status: Integer);
if Status = 0 then
// show error
Thank you very much for your reply
Your code does not work I have tried it in a lot of ways, but is not it a simple example you can throw?
Thank you
Thank you
Answered in a private message
