Problem with MergeCells and SaveRTF
CGM
Post by CGM »
I got a problem when loading RichView from a rtf-file when using TRVTableItemInfo and MergeCells.
When loading the RichView from a rtf-file the merged cells format in a strange format (se attached image and code in Unit1.zip).
Any ideas ?
/Thanks
Using TRichView v16.9.5
Unit1.zip
(1.86 KiB) Downloaded 1279 times
Re: Problem with MergeCells and SaveRTF
I included your unit in a new project compiled with the newest version of TRichView (16.13.5), and the table loaded from RTF is exactly the same as it was originally created.
Try to install a new TRichView version and re-test.
CGM
Post by CGM »
Hi
Thanks for the quick reply :D .
As you stated in your reply it's working just fine in 16.13.5.
