Printing footer
jota
Printing footer
Post by jota »
Hi
Is there a property in trvprint to get the coordinates of the foot inside the page to be printed?
Thanks in advance
Re: Printing footer
I assume you ask about a footer assigned by TRVPrint.SetFooter.
Its position is defined by TRVPrint.FooterY: a distance from the page bottom to the footer bottom, measured in TRVPrint.Units.
jota
Re: Printing footer
Post by jota »
Hi
I´m looking for coordinates of the foot to present a TextOut with page counter, in the OnPagePostpaint event, so that I can collect updated or recalculate those coordinates when I use trvprintpreview.
Re: Printing footer
Do you mean a text header/footer drawn by RichViewActions?
They draw header above the main page text, and footer below the main page text. Main page text is in the rectangle specified in PrintAreaRect parameter of OnPagePrepaint.
It is calculated using TRVPrint.Margins property (TopMargin and BottomMargin)
See the code in RichViewActions:
    ppi := Canvas.Font.PixelsPerInch;
    h := Canvas.TextHeight(S);
    if Header then
      Y := PrintAreaRect.Top - h - ppi div 20
      Y := PrintAreaRect.Bottom + ppi div 20;
    R := Rect(PrintAreaRect.Left, Y, PrintAreaRect.Right, Y + h);
    DrawText(Canvas.Handle, PChar(S), Length(S), R, ...)
