Printing question
Guest
Printing question
Post by Guest »
I am working on a product to keep daily notes. Each note will be saved in an RTF file for that specific day.
When it comes time to print the notes, the user might want to print a range - one or two weeks worth or a years worth - at one time. These could be printed each on its own page, but some might be only one or two paragraphs.
Is there any sort of methodology to either combine multiple files before printing (which might result in a huge file), or, preferably, to sort of "stream" the print output so that if wenesday's entry takes only 1/3 page, that I can fill up the rest of the page with Thursday's entry, which might wrap to the next page,... and so on..?
I created a little FAQ about printing, I hope you'll find an answer there:
http://www.trichview.com/forums/viewtopic.php?p=255
