How to set cursor at the end of document ?
Marsianin
Post by Marsianin »
I want to implement 'entire scope' search (which is not implemented for RichViewEdit) and need to set cursor to the end of the document when direction is UP.
I'm using RVSetLinearCaretPos but don't know how to get the last symbol position number.
rve.SetSelectionBounds(rve.ItemCount-1, rve.GetOffsAfterItem(rve.ItemCount-1), rve.ItemCount-1, rve.GetOffsAfterItem(rve.ItemCount-1))
Marsianin
Post by Marsianin »
And how to use it ?
And how to get the last character number in the text ? Will it be rve.ItemCount-1 ?
Marsianin
Post by Marsianin »
Just read the help :)
  ItemNo, Offs: Integer;
ItemNo := MyRichViewEdit.ItemCount-1;
Offs   := MyRichViewEdit.GetOffsAfterItem(ItemNo);
MyRichViewEdit.SetSelectionBounds(ItemNo,Offs,ItemNo,Offs);
Same code as you posted above. Thanks.
Marsianin
Post by Marsianin »
But another one question.
Is there a way to perform search in all document without changing position of the caret ?
What do you mean by "without changing position of the caret"? Not changed if nothing is found, or not changing at all?
May be you are searching for something like this:
http://www.trichview.com/forums/viewtopic.php?t=57
recbeat
Could not make this work
Post by recbeat »
I tried the code you suggested but to no avail. I got 'List index out of bounds (-1)' error. I added one item into RichView to test this in order to add text to the end of the document:
What is wrong? I'm trying this on Delphi 7.
Thanks for any help.
May be your RichViewEdit was not formatted?
recbeat
Post by recbeat »
Hello Sergey,
Yes, the 'Format' call figured this out. Thanks!
