Simple Search and Replace
don709
Post by don709 »
Having searched whatever I could on this topic and trying numerous approaches over the last day and a half I have to admit I cannot figure out this simple task.
I load a template file in rtf format into a ScaleRichView and search for something like [LastName] and replace it with something like Walsh
Here is the simplest code I could fine
with RVEPreview do
RichViewEdit.SetSelectionBounds(0, RichViewEdit.GetOffsBeforeItem(0), 0, RichViewEdit.GetOffsBeforeItem(0));
while RichViewEdit.SearchText('['+OldWord+']', [rvseoDown,rvseoWholeWord]) do
RichViewEdit.InsertText(NewWord);
soon as it tries the SearchText statement I get the following error
List index out of bounds (-1)
My versions are ScaleRichView 7.5 and Richview 16.9
Thanks for any help you might offer
Don
May be the document in RichViewEdit is not formatted?
SearchText and InsertText requires formatted documents.
Call RichViewEdit.Format before replacing.
don709
Post by don709 »
Wow... simple fix.
Worked perfectly.
Thank you so much.
