ApplyStyleConversion not working?
martindholmes
Post by martindholmes »
Hi there,
I'm trying this relatively simple task with a TRichViewEdit:
rve.ApplyStyleConversion(TEXT_BOLD);
It has no effect. Can anyone suggest why that might be? I've gone through all the options and settings I can find, but I can't see what's preventing this from working.
All help appreciated,
Martin
ApplyStyleConversion calls OnStyleConversion event for each selected text item, passing its parameter (TEXT_BOLD in your case) as one of parameters to this event.
If you do not process this event, ApplyStyleConversion will do nothing. Example can be found in Demos\Editors\Editor 2\
martindholmes
Doh! Thanks Sergey. Missed the obvious there.
Cheers,
Martin
