insert blank page
cychia_n2n
insert blank page
Post by cychia_n2n »
How can I insert blank page like MS Word feature?
I am not sure which MS Word feature you mean.
You can insert a page break in the caret position.
If you use RichViewActions, you can use rvActionInsertPageBreak action.
If you do not use RichViewActions, call RichViewEdit.InsertPageBreak.
cychia_n2n
Insert Blank page for ms word will insert a new blank page at the caret position.
I tried call InsertPageBreak twice, it can create the correct result, but how can I maintain the caret in the blank page?
cychia_n2n
Hi, anyone have solution for my need?
Thanks.
