has anyone found a good solution to insert math formulas ?
By accident I ran into mimetex today, which can easily generate a gif image from a math formula.
So I'm thinking of using mimetex as a formula generator,
translate the gif imag into png image,
using the alternate text property as the formula source,
so changes to the formula can still be made afterwards.
Is this a bad idea ?
Are there other solutions ?
thanks,
math formula ?
I implement math formula in TRichViewEdit in two ways^
1. MS Word Equation Editor
2. Internal editor based on ExprDraw (www.delphikingdom.com - in Russian). Example: http://www.rsoftware.net/exprguide.exe
There is some troubles:
1. In my case (delphi5, office2000) doesn't export in RTF
2. Partially implemented (not save original formula text, waiting for RVA update).
thanks,
I tried MS Equation editor, and besides it's OLE with all its trouble, I couldn't get the buttonbar shown automatically.
The Russion site was akakadabra to me
So I tried MimeTex, and it works well and is good enough for me.
You can see some impressions here
http://oase.uci.kun.nl/~mientki/pic/jal ... ditor.html
I've also made an example, showing all the features shown on the site above. I'll send this example to Sergey and ask him to put this in the examples section.
