line break in cell
rellik
line break in cell
Post by rellik »
Hi! I need paste text into cell of table.
I use table1.cell[0, 0].addNL(s);
but if s = 'перенос '+#10#13+'строки'; SrichViewEdit ignore it and paste into cell 'перенос строки'
To add multiline text, use AddTextNL:
table.Cells[0,0].AddTextNL('line1'#10#13'line2', 0, 0, 0);
rellik
Post by rellik »
Thanks, I can see, how many lines in the text of the cell?
I assume that "lines" means "paragraphs" (including line breaks inside paragraphs)
function GetParaCount(RVData: TCustomRVData): Integer;
var i: Integer;
  Result := 0;
  for I := 0 to RVData.ItemCount - 1 do
    if RVData.IsFromNewLine(I) then
      inc(Result);
Call:
ParaCount := GetParaCount(table.Cells[0,0].GetRVData);
