COPY AND INSERT
COPY AND INSERT
1, in my RichViewEdit, i selected some text and gif(TGIFImage), and press CTRL+C, CTRL+P,bug only paste the text ,has not gif? is anywhere set wrong? i can copy form Demo Application.
2,in my RichViewEdit, i set caret pos at middle of some words,then insert one gif, how to get the latest inserted ItemNo(gif)? maby has many gif in RichViewEdit.
i used RichView a few days, so mush content, search some qustion is so slow.very thans.
i already register class in formMain.Create method:
RegisterClass(TGifImage);
CTRL+C,CTRL+P however has no image.
i maby already insert few gif in it, then i set caret to middle of them with mouse, and insert new gif, this time, the carset is not at after the latest inserted gif.
i select gif from a frame,and add to the parent form`s RichViewEdit.
var gif: TGIFImage;
gif:=TGIFImage.Create;
gif.Assign(gr);
TformMsg(fmMsg).RichViewEditSend.InsertPicture(s,gif,rvvaBaseLine);
TformMsg(fmMsg).RichViewEditSend.Format;
hide;
TformMsg(fmMsg).RichViewEditSend.SetFocus;
All Add*** methods need format. They should be used for document generation: rv.Clear, then calling one or more Add*** methods, then call rv.Format.
Generally, all methods for document modification introduced in TRichView need calling Format (they are marked in the help file as "viewer-style methods", all method introduced in TRichViewEdit reformat document automatically (they are marked in the help file as "editing-style methods").
See "Viewer vs Editor" help topic for details.
As for copy-pasting Gifs, see my answer before.
I do not know why bitmaps are not loaded. You can save this document in RVF file and send to me, I'll try to see what's wrong.
1, because i set rvoAutoCopyRVF to false,os i can`t copy bitmap from rv,i turn it true, is OK,can copy bitmap now.
2, i reRegister TGIFImage Class at Here
now can copy gif from one rv to other rv normal. but when i copy some text and gif together , or copy more than one gif, is same , the application is stop respond, CPU used 99% with my application,why? if i copy only one gif , it can work normal
Application.Initialize;
Application.CreateForm(TformMain, formMain);
Application.Run;
end.
