File is too big when i pasted some pictures from ClipBoard
linsoo
Post by linsoo »
Question 1:
I want't to reduce the file size when many pictures were pasted from Clipboard.
Code below worked, the file size is small. But the pictures in file are so distortion:
procedure TResearchReportFrame.RichViewEdit1Paste(Sender: TCustomRichViewEdit;
  var DoDefault: Boolean);
  png : TPngImage;
  gr : TGraphic;
  if Clipboard.HasFormat(CF_BITMAP) then
    DoDefault := False;
    png := TPngImage.Create;
    png.LoadFromClipboardFormat(CF_BITMAP,ClipBoard.GetAsHandle(CF_BITMAP),0);
    gr := RV_CreateGraphics(TGraphicClass(png.ClassType));
    gr.Assign(png);
//    png.SaveToFile('d:\1.png');
    RichViewEdit1.ActiveEditor.InsertPicture('',gr, rvvaLeft);
    png.Free;
  end
    DoDefault := True;
Is there any way to deal this?
Question 2:
Mouse wheel in TSRichViewEdit is so slow.
If I set this property geater than 10, the mouse wheel will not work.. , Is there any other property?
TSRichViewEdit.ViewProperty.WheelStep
TSRichViewEdit.RichViewEdit.WheelStep
Thanks.
linsoo
Post by linsoo »
Question 2 was solved by this code:
procedure TResearchReportFrame.RichViewEdit1VScrolled(Sender: TObject);
  if RichViewEdit1.ScrollBarV.Position > OldPosition then
    RichViewEdit1.ScrollBarV.Position := RichViewEdit1.ScrollBarV.Position + RichViewEdit1.ViewProperty.WheelStep;
  end
  else if RichViewEdit1.ScrollBarV.Position < OldPosition   then
    RichViewEdit1.ScrollBarV.Position := RichViewEdit1.ScrollBarV.Position - RichViewEdit1.ViewProperty.WheelStep;
  OldPosition := RichViewEdit1.ScrollBarV.Position;
Although it's not very butilfull...
1. I cannot see problems with the code.
In my tests, the inserted PNG image looks exactly like the source bitmap.
It's only too complicated, and may be simplified to
procedure TForm3.SRichViewEdit1Paste(Sender: TCustomRichViewEdit;
   png : TPngImage;
     DoDefault := False;
     SRichViewEdit1.ActiveEditor.InsertPicture('', png, rvvaAbsMiddle);
I also changed the image alignment from left to absMiddle.
2. As for mouse wheel, the default setting work fine for me.
However, I can see ViewProperty.WheelStep is processed incorrectly, larger values decrees scrolling speed. It will be fixed in the next update.
WheelStep is fixed. In the last update, larger values of ViewProperty.WheelStep increase scrolling speed.
