Report Workshop 1.0
Report Workshop 1.0
We are happy to announce the availability of our new reporting components: Report Workshop. They allow designing reports in TRichView (or ScaleRichView) editors, and build these reports in these editors as well.
Both report templates and report results are word processing documents that can be stored in RVF format. They can be printed, exported to HTML, DocX and RTF (and PDF, using third-party PDF components). You can apply styles to report templates and report results to change their appearance.
Information: Online help: http://www.trichview.com/help-report/
Trial version and demo projects
Trial version can be downloaded from http://www.trichview.com/download/
A compiled demo (report designer using FireDAC) is included in TRichView demos, or can be downloaded separately: http://www.trichview.com/rvfiles/report ... p-demo.zip
Ordering
Report Workshop is a TRichView add-on, so they can be ordered together:
http://www.trichview.com/order/
Registered TRichView users can order Report Workshop separately.
The current prices are introductory, they are available for a limited time!
There are some possibilities to get our components without payments, see http://www.trichview.com/forums/viewtopic.php?t=7634
Any questions are welcome.
A small example, how to make a report
1. Create a rich text document
2. Assign data queries to fragments of this document (usually table rows)
3. Make a report
I changed defaults in the compiled demo.
Previously, when starting, it tried to load dbdemos.gdb using InterBase. It could not be loaded if you do not have InterBase server installed and running, or you have InterBase version prior to XE.
The new version loads dbdemos-old.gdb using embedded version of FireBird.
(dbdemos.gdb and dbdemos-old.gdb contain the same tables, but dbdemos.gdb can be loaded by InterBase XE, XE3 and XE7, dbdemos-old.gdb can be loaded by FireBird 2.x and older versions of InterBase)
