Hello
Since my last update (TRichView16Setup16.8.6) my XE7 compiler shows this line 10 times. Any idea on how to make it stop.
[dcc32 Hint] H2161 Warning: Duplicate resource: Type 2 (BITMAP), ID BMP0; File D:\myProgramFiles\Delphi Library\TRichView\RichViewActions\Source\RulerSkins.RES resource kept; file D:\myProgramFiles\Delphi Library\TRichView\RichViewActions\Source\RulerSkins.RES resource discarded.
Weird how it can keep and discard the same file at the same time... 10 times
Doesn't stop the program from compiling it's just somewhat annoying.
Cheers
Don
Duplicate Resource
The new version renames Ruler.pas to RVRulerBase.pas (it was done to avoid conflicts with other third-party components).
If you did not remove a reference to Ruler unit from your project, both Ruler and RVRulerBase units are included in your project.
Delete Ruler.pas and Ruler.dcu from your hard drive (they are in <TRichView Dir>\RichViewActions\Source\), and change "Ruler" to "RVRulerBase" in "uses" of units of your project.
Duplicate Resource
When I delete RVRuler from the hard drive SclRVRuler won't compile
