[Example] Converting all images to Jpegs
This C++ code converts all images in RichViewEdit1 to Jpeg format.
This is not an editing procedure (it cannot be undone and redone by users).
This code uses RVData->EnumItems() which calls the specified procedure (EnumItemsProc in this demo) for all items.
Code for TRichView 17.3 and newer, for all versions of C++Builder:
#include "RVGrHandler.hpp"
void __fastcall TfrmMain::EnumItemsProc(TCustomRVData* RVData,
  int ItemNo, int& UserData1, const TRVUnicodeString UserData2,
  bool& ContinueEnum)
  ContinueEnum = true;
  if (RVData->GetItem(ItemNo)->InheritsFrom(__classid(TRVGraphicItemInfo)))
	TRVUnicodeString s;
	TGraphic* gr;
	TRVVAlign VAlign;
	TRVTag Tag;
	RVData->GetPictureInfo(ItemNo,s,gr,VAlign,Tag);
	if (gr->InheritsFrom(__classid(TJPEGImage)))
	  return;
	Graphics::TBitmap* bmp = RVGraphicHandler->ToBitmap(gr);
	TJPEGImage* jpg = new TJPEGImage;
	jpg->Assign(bmp);
	delete bmp;
	RVData->SetPictureInfo(ItemNo,s,jpg,VAlign,Tag);
void __fastcall TfrmMain::Button1Click(TObject *Sender)
  int v=0;
  RichViewEdit1->RVData->EnumItems(EnumItemsProc, v, "");
  RichViewEdit1->Invalidate();
The same code for TRichView 17.2 and older:
void __fastcall TForm1::EnumItemsProc(TCustomRVData* RVData,
  int ItemNo, int& UserData1, const UnicodeString UserData2,
  bool& ContinueEnum)
    AnsiString s;
    TGraphic* gr;
    TRVVAlign VAlign;
    TRVTag Tag;
      return;
    Graphics::TBitmap* bmp = new Graphics::TBitmap;
      bmp->Assign(gr);
    catch(...)
      bmp->Width = gr->Width;
      bmp->Height = gr->Height;
      bmp->Canvas->Draw(0, 0, gr);
    jpg->Assign(bmp);
    delete bmp;
void __fastcall TForm1::Button1Click(TObject *Sender)
  int v=0;
For C++Builder 6 and 20007, change the type of UserData2 from UnicodeString to AnsiSting.
Update:
2018-Apr-16: new code compatible with TRichView 17.3.
Last edited by Sergey Tkachenko on Wed Apr 16, 2014 11:20 am, edited 2 times in total.
Similar procedure for Delphi, converting all images to bitmaps
Code for TRichView 17.3 and newer:
uses RVTypes, RVGrHandler, CRVData;
procedure TForm1.EnumItemsProc(RVData: TCustomRVData;
  ItemNo: Integer; var UserData1: Integer; const UserData2: TRVUnicodeString;
  var ContinueEnum: Boolean);
  gr: TGraphic;
  bmp: TBitmap;
  Tag: TRVTag;
  VAlign: TRVVAlign;
  s: TRVUnicodeString;
  if RVData.GetItem(ItemNo) is TRVGraphicItemInfo then
    RVData.GetPictureInfo(ItemNo,s,gr,VAlign,Tag);
    if not (gr is TBitmap) then
      bmp := RVGraphicHandler.ToBitmap(gr);
      RVData.SetPictureInfo(ItemNo,s,bmp,VAlign,Tag);
  ContinueEnum := True;
  ItemNo: Integer; var UserData1: Integer; const UserData2: String;
var gr: TGraphic;
    bmp: TBitmap;
    Tag: TRVTag;
    VAlign: TRVVAlign;
    s: TRVAnsiString;
  if RVData.GetItem(ItemNo) is TRVGraphicItemInfo then begin
    bmp := TBitmap.Create;
      bmp.Assign(gr);
    except
      bmp.Width := gr.Width;
      bmp.Height := gr.Height;
      bmp.Canvas.Draw(0, 0, gr);
Call:
var v: Integer;
  v := 0;
  RichViewEdit1.RVData.EnumItems(EnumItemsProc, v, '')
Update:
Converting all images to Jpegs, Delphi version.
uses CRVData, RVGrHandler, RVTypes;
var gr: TGraphic;
    jpg: TJPEGImage;
    bmp: TBitmap;
    Tag: TRVTag;
    VAlign: TRVVAlign;
    if not (gr is TJPEGImage) then
      jpg := TJPEGImage.Create;
      jpg.Assign(bmp);
      bmp.Free;
      RVData.SetPictureInfo(ItemNo,s, jpg,VAlign,Tag);
procedure TForm3.EnumItemsProc(RVData: TCustomRVData;
var gr: TGraphic;
    jpg: TJPEGImage;
    bmp: TBitmap;
    Tag: TRVTag;
    VAlign: TRVVAlign;
    s: TRVAnsiString;
    if gr is TJPEGImage then
      bmp.Assign(gr);
    except
    jpg.Assign(bmp);
    bmp.Free;
Call:
var v: Integer;
  v := 0;
Update:
Re: [Example] Converting all images to Jpegs
These examples work in the new version of TRichView, but all string types used in them (String, TRVAnsiString) must be changed to TRVUnicodeString.
