Animated Gif
max.beliy
Animated Gif
Post by max.beliy »
Is it possible to show gif animation in RV?
Yes.
If you use Delphi 2007 or newer, include RVGifAnimate2007 unit in your project
(for older versions, you need to use third-party gif classes)
Also, you can change RichViewEdit.AnimationMode to rvaniOnFormat to start animation automatically.
max.beliy
Post by max.beliy »
It works with standart RVE but with cxTRichViewEdit doesn't work :(
I confirm the problem: if you set cxrv.Properties.Properties.AnimationMode = rvaniOnFormat at designtime, it does not work.
Fix: open cxTRichView.pas, find procedure TcxCustomTRichViewEdit.Loaded, change it to:
procedure TcxCustomTRichViewEdit.Loaded;
  inherited;
  ShortRefreshContainer(False);
  if InnerEditor <> nil then
    InnerEditor.Loaded;
This fix will be included in the next update.
max.beliy
Post by max.beliy »
max.beliy
Post by max.beliy »
But still doesn't work :(
How do you load the image? The animation is supported if it is loaded as TGifImage, not as DevExpress graphic class (TdxSmartImage)
If you load a gif file using TPicture.LoadFromFile or RVGraphicHandler.LoadFromFile, the most probably, the image is loaded as TdxSmartImage.
You can unregister TdxSmartImage by calling
TPicture.UnregisterGraphicClass(TdxSmartImage);
when the application starts (include dxGDIPlusClasses in "uses").
max.beliy
Post by max.beliy »
Thanks TPicture.UnregisterGraphicClass(TdxSmartImage); Works !
Also in some cases can help moving declaration of dx*** units before:
GifImg, RVGifAnimate2007
