How to define defaul File name and path before SaveAs action
max.beliy
Post by max.beliy »
How I can define default file name and path for showing them in
rvActionSaveAs dialog ?
RVAControlPanel.DefaultFileName
If you want to change the default format as well, assign also DefaultExt and DefaultFileFormat properties
max.beliy
Post by max.beliy »
It works only once at design time, but in run time changing of
RVAControlPanel.DefaultFileName doesn't work, and the file name is still same as set in design time.
max.beliy
Post by max.beliy »
TrvaDocumentInfo(rvActionSave1.Documents[rvActionSave1.FindDoc(RichViewEdit1)]).FileName := ...
This property is applied every time you call RvActionNew.Execute.
Yes, if you need changing file name AFTER its assigning, you can change
rvActionSave1.GetDoc(RichViewEdit1).FileName.
It works both for default file name (assigned by New) and for exact file name (assigned by Open or SaveAs).
