Hi;
I want to know how to change page size to A5 format at run time
thank you.
Page format
While ScaleRichView can automatically set paper size when printing, TRichView uses the paper format specified for the printer.
So, if you want to print on A5 paper, you need to set this format to the printer before printing.
This code shows how to do it:
Call
After that, you can print using TRVPrint component: call AssignSource, FormatPages, Print methods.
uses Printers;
procedure SetPaperSize(PaperSize: Integer);
var ADevice, ADriver, APort: array[0..79] of Char;
ADeviceMode: THandle;
DevMode: PDeviceMode;
Printer.GetPrinter(ADevice,ADriver,APort,ADeviceMode);
if ADeviceMode<>0 then begin
DevMode := PDeviceMode(GlobalLock(ADeviceMode))
end
raise Exception.Create('Error initializing printer');
DevMode.dmFields := DevMode.dmFields or DM_PAPERSIZE;
DevMode.dmPaperSize := PaperSize;
GlobalUnlock(ADeviceMode);
Printer.SetPrinter(ADevice,ADriver,APort,ADeviceMode);
SetPaperSize(DMPAPER_A5)
