Search and Replace text in Header
DelphiDude
Post by DelphiDude »
i have the srichview working with loading an rtf and the do a search and replace but how do i get it to search and replace info in the header.
Just curious since the search and replace with the srichview needs to be done programmatically, is there a better/simpler way to search and replace all of a select text with my text?
Here is the search and replace code:
    rveDoc.RichViewEdit.SetSelectionBounds(0, rveDoc.RichViewEdit.GetOffsBeforeItem(0), 0, rveDoc.RichViewEdit.GetOffsBeforeItem(0));
    if rveDoc.RichViewEdit.SearchText(InSearch,[RVEdit.TRVESearchOption.rvseoMatchCase,
    RVEdit.TRVESearchOption.rvseoDown, RVEdit.TRVESearchOption.rvseoMultiItem]) then
      rveDoc.RichViewEdit.InsertText(InReplace, False);
      while (rveDoc.RichViewEdit.SearchText(InSearch,[RVEdit.TRVESearchOption.rvseoMatchCase,
    RVEdit.TRVESearchOption.rvseoDown, RVEdit.TRVESearchOption.rvseoMultiItem,
    RVEdit.TRVESearchOption.rvseoSmartStart])) do
To search in the active sub-editor (main document, header, footer, note, text box), use ActiveEditor instead of RichViewEdit:
rveDoc.ActiveEditor.SetSelectionBounds(
  0, rveDoc.ActiveEditor.GetOffsBeforeItem(0),
  0, rveDoc.ActiveEditor.GetOffsBeforeItem(0));
while (rveDoc.ActiveEditor.SearchText(InSearch,[RVEdit.TRVESearchOption.rvseoMatchCase,
        rveDoc.ActiveEditor.InsertText(InReplace, False);
If you need this replacement as an editing (undoable) operation, this use this code.
DelphiDude
Still not getting my header updated...
Here is my loading of the rtf file.
      rveDoc.Clear;
      rveDoc.ActiveEditor.LoadRTF(_rtfDirectory + cklstbxRTF.Items.Items[I].Text + '.rtf');
      rveDoc.Format;
      rveDoc.Update;
then after i get my data from the DB i call the search and replace routine.
procedure TfrmHKLDocuments.SearchAndReplace(InSearch, InReplace: string) ;
  startpos, Position, endpos: integer;
    rveDoc.CanUpdate := False;
    rveDoc.SetBusy(True);
    rveDoc.StopCursor;
   rveDoc.StartCursor;
   rveDoc.SetBusy(False);
   rveDoc.CanUpdate := True;
then i save the file.
      if sdDocFile.Execute() then
        rveDoc.ActiveEditor.SaveDocX(sdDocFile.FileName, False);
        ShellExecute(0, 'open', Pchar(sdDocFile.FileName), nil, nil, SW_SHOWNORMAL);
      end
        rveDoc.ActiveEditor.SaveDocX(_docDirectory + _KeyID + ' - ' +
          Trim(cklstbxRTF.Items.Items[I].Text) + '.doc', False);
when the WORD open the new file the header text is unchanged.
First, about loading. To load a new document, load it in SRV.RichViewEdit, not in SRV.ActiveEditor.
Because, if a note or a header is active, the document will be loaded in this note or a header. So the code is:
      rveDoc.Clear;
      rveDoc.RichViewEdit.LoadRTF(_rtfDirectory + cklstbxRTF.Items.Items[I].Text + '.rtf');
      rveDoc.Format;
As for replacing:
procedure TfrmHKLDocuments.SearchAndReplace(InSearch, InReplace: string; Editor: TSRVRichViewEditType) ;
    if not rveDoc.StartEditing(Editor) then
To replace in the main document, call SearchAndReplace(..., srvrveMain).
To replace in the header of the current page, call SearchAndReplace(..., srvrveHeader).
To replace in the footer of the current page, call SearchAndReplace(..., srvrveFooter).
