RichView Screen Capture
phowlett
Post by phowlett »
Is there a similar facillty to Screen Clipping in MS OneNote
Thank you
Regards
Peter Howlett
Can you explain what it should do?
phowlett
Post by phowlett »
Take and insert a screen image, called a screen clipping
Capture an image when OneNote is open
Place the insertion point in your notes where you want to add the image.
On the Insert menu, click Screen Clipping.
OneNote is minimized, and the last active window becomes visible.
Drag the pointer to create a rectangular selection.
It is like a screen capture tool which automatically inserts capture into notes that would be into a RichViewEdit
Sorry, I think this feature should be implemented at application level, not by an editing component.
Stef
Post by Stef »
I realized this, using ASGScreenCapture (a freeware component from William Miller). works great !!
cheers,
