Image Warp Behind Text/ Text Vertical Align
mboloz
Post by mboloz »
Is there any way to make image copy from MS Doc, sent behind the text? or there any way to make the text vertical align center of the image?
You can use VAlign property of the picture item.
In RichViewActions, it can be changed in two places:
1) "Object Properties" dialog. Tab "Position and size", set "align middle to line middle".
or
2) "Object Position" dialog, set "align middle to line middle".
mboloz
Post by mboloz »
Sergey Tkachenko wrote:You can use VAlign property of the picture item.
or
:D Thank You, Solved...
