Xhtml missing from Save(As)Action?
wvd_vegt
Post by wvd_vegt »
Just tried the actions add-on and noticed that saving as xhtml is missing from the save(as) dialogs filetype filters.
I can't find where to add it.
Since it's only export, not import, HTML saving functions are available only in the TrvActionExport.
And this action was implemented before XHTML support, so it does have separate items in the file filter for it. You can save either HTML or XHTML using this action, depending on rvActionExport.SaveOptions
