Clerk hello:
Excuse me, recently a lot of customer response, my ScaleRichView when using paste, if the Chinese content, paste it is garbled,
thank you
Paste the Chinese is garbled
I read your answer.
You use non-Unicode version of Delphi, so, by default, text in ScaleRichView content is not Unicode. TRichView and ScaleRichView require to be Unicode to handle Chinese text properly.
You copies text from MS Word, so, copying occurs in RTF format.
I suggest to call this code to convert content of TSRichViewEdit to Unicode:
Call ConvertSRVToUnicode to convert your TSRichViewEdit control to Unicode when the application starts. If your application loads RVF files, you need to call this function after loading as well.
If TSRichViewEdit is already displayed, call SRichViewEdit.Format after this procedure.
procedure ConvertRVDataToUnicode(RVData: TCustomRVData);
i, R, c, StyleNo: Integer;
table: TRVTableItemInfo;
for i := 0 to RVData.ItemCount - 1 do
StyleNo := RVData.GetItemStyle(i);
if StyleNo >= 0 then
if not RVData.GetRVStyle.TextStyles[StyleNo].Unicode then
RVData.SetItemTextR(i, RVU_GetRawUnicode(RVData.GetItemTextW(i)));
Include(RVData.GetItem(i).ItemOptions, rvioUnicode);
end
else if RVData.GetItem(i) is TRVTableItemInfo then
for R := 0 to table.Rows.Count - 1 do
for c := 0 to table.Rows[R].Count - 1 do
if table.Cells[R, c] <> nil then
ConvertRVDataToUnicode(table.Cells[R, c].GetRVData);
procedure ConvertRVToUnicode(rv: TCustomRichView);
i: Integer;
ConvertRVDataToUnicode(rv.RVData);
for i := 0 to rv.Style.TextStyles.Count - 1 do
rv.Style.TextStyles[i].Unicode := True;
procedure ConvertSRVToUnicode(srv: TSRichViewEdit);
HF: TSRVHeaderFooterType;
for HF := Low(TSRVHeaderFooterType) to High(TSRVHeaderFooterType) do
ConvertRVDataToUnicode(srv.SubDocuments[HF]);
ConvertRVToUnicode(srv.RichViewEdit);
ConvertRVToUnicode(srv.RVHeader);
ConvertRVToUnicode(srv.RVFooter);
srv.RTFReadProperties.UnicodeMode := rvruOnlyUnicode;
TSRVHeaderFooterType need to refer to the unit
Thank you, can you tell me the TSRVHeaderFooterType need the unit, I won't compile
If you use the older version, without SubDocuments property, the last procedure must be
