Memory leak in TDBRichView
PioPio
Post by PioPio »
I have the following code:
unit Unit1;
interface
uses
  Winapi.Windows,
  Winapi.Messages,
  System.SysUtils,
  System.Variants,
  System.Classes,
  Vcl.Graphics,
  rvstyle,
  Vcl.Controls,
  Vcl.Forms,
  Vcl.Dialogs,
  RVScroll,
  RichView,
  RVEdit,
  DBRV;
type
  TForm1 = class(TForm)
    procedure FormActivate(Sender: TObject);
    procedure FormDestroy(Sender: TObject);
  private
    { Private declarations }
    FForm: TForm;
    FRVStyle: TRVStyle;
    FDBRichViewEdit: TDBRichView;
  public
    { Public declarations }
  Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.FormActivate(Sender: TObject);
  FRVStyle := TRVStyle.Create(nil);
  FDBRichViewEdit := TDBRichView.Create(nil);
  FDBRichViewEdit.Parent := Self;
  FDBRichViewEdit.Style := FRVStyle;
  FDBRichViewEdit.Visible := True;
procedure TForm1.FormDestroy(Sender: TObject);
  FRVStyle.Free;
  FDBRichViewEdit.Free;
The application compiles and runs regularly but MadExcept http://madshi.net/madExceptDescription.htm detects a problem when I close the application. The following is the report:
end.allocation number: 1932
program up time: 1.22 s
type: OpenThemeData
address: $b0002
access rights: ./.
main thread ($1fa8):
671d409a madExcept32.dll madExceptDbg 5504 OpenThemeDataCallback
006eb314 Project2.exe RVScroll 1289 TRVScroller.CreateThemeHandle
006e9acd Project2.exe RVScroll 499 TRVScroller.CreateWnd
00514fbe Project2.exe Vcl.Controls TWinControl.CreateHandle
00515288 Project2.exe Vcl.Controls TWinControl.UpdateShowing
005152b6 Project2.exe Vcl.Controls TWinControl.UpdateShowing
00515430 Project2.exe Vcl.Controls TWinControl.UpdateControlState
00514682 Project2.exe Vcl.Controls TWinControl.InsertControl
0050fba8 Project2.exe Vcl.Controls TControl.SetParent
0051ae9d Project2.exe Vcl.Controls TWinControl.SetParent
0074ff98 Project2.exe Unit1 45 TForm1.FormActivate
00591c27 Project2.exe Vcl.Forms TCustomForm.Activate
00592ce8 Project2.exe Vcl.Forms TCustomForm.CMActivate
005115c5 Project2.exe Vcl.Controls TControl.WndProc
00515f23 Project2.exe Vcl.Controls TWinControl.WndProc
0058f24d Project2.exe Vcl.Forms TCustomForm.WndProc
00515578 Project2.exe Vcl.Controls TWinControl.MainWndProc
00489538 Project2.exe System.Classes StdWndProc
7650558d USER32.dll SendMessageW
0058c12c Project2.exe Vcl.Forms SendFocusMessage
00515b27 Project2.exe Vcl.Controls TWinControl.WndProc
7794700b ntdll.dll KiUserCallbackDispatcher
00511200 Project2.exe Vcl.Controls TControl.Perform
00515321 Project2.exe Vcl.Controls TWinControl.UpdateShowing
0051803e Project2.exe Vcl.Controls TWinControl.CMVisibleChanged
0050fbde Project2.exe Vcl.Controls TControl.SetVisible
00759a49 Project2.exe Project2 18 initialization
7645ef1a kernel32.dll BaseThreadInitThunk
It seems the issue is generated by the line
because if I comment it out I have no warnings but in this case some operations cannot be performed by TDBRichViewEdit. How can I solve the issue ?
Many thanks
Alberto
PioPio
Post by PioPio »
It turned out that if I set
FNiftyDBRichViewEdit.UseXPThemes:=False;
then I have no warning memory leak notification messages from MadExcept.
Why is it ? Is there any way to keep UseXPThemes=True without having memory leaks ?
Many thanks
Alberto
Please tell me versions of TRichView, madExcept and Delphi.
I tried your code with the newest version of TRichView (however, no changes related to theme handles were made for a very long time), Delphi 10, MadExcept 4.0.13.
MadExcept reported no leaks.
You can put breakpoints in
and
TRVScroller.FreeThemeHandle
You will see that TRVScroller.CreateThemeHandle is called when you assign Parent, and TRVScroller.FreeThemeHandle is called when you close the form.
PioPio
Post by PioPio »
Sergey Tkachenko wrote:Please tell me versions of TRichView, madExcept and Delphi.
I have:
TRichView 15
madExcept 4.0.14
Delphi XE 2
I upgraded madExcept to 4.0.14 and tried this project in XE2.
madExcept still does not report any leaks with the latest version of TRichView.
I am quite sure that nothing was changed related to theme handle allocation and de-allocation since TRichView v15.0.
Did you try breakpoints as I suggested?
I tested in Windows 8.1
