Interesting...
SKinneyx1
Interesting...
Post by SKinneyx1 »
Tell me where I'm going wrong here:
I've wrote a little application to display PDB Documents. When a document is closed I want to capture the last page the user was viewing so that when they reopen the document I can put them back there.
Accordingly, I snag RichView1.FirstItemVisible during closing. Works fine. However, when I go to put them back it always comes up several paragraphs shy. Digging through the code, the only thing I could find to set the position was SetSelectionBounds. Is there something else to set the first visible item that I'm missing?
Thanks.
FirstItemVisible is not very accurate, it can return an item just on top of visible area.
If editor window in your application has a fixed width (or its width is restored to the last remembered value when the application starts), the simplest way is to store and restore VScrollPos value.
