How Export rvf file to Jpeg.
Thanks.
procedure SavePageAsJpeg(SRV: TSRichViewEdit; PageNo: Integer; const FileName: String);
bmp: TBitmap;
jpg: TJPEGImage;
bmp := TBitmap.Create;
bmp.Width := SRV.PageWidth100Pix;
bmp.Height := SRV.PageHeight100Pix;
SRV.DrawPage(PageNo, bmp.Width, bmp.Height, 0, 0, bmp.Canvas,
False, True, False, False);
jpg := TJPEGImage.Create;
jpg.Assign(bmp);
jpg.SaveToFile(FileName);
jpg.Free;
bmp.Free;
procedure TForm3.ToolButton79Click(Sender: TObject);
i: Integer;
for i := 1 to SRichViewEdit1.PageCount do
SavePageAsJpeg(SRichViewEdit1, i, ExtractFilePath(Application.ExeName) +
'page' + IntToStr(i) + '.jpg');
I suggest using PNG instead. The code is the same, but use TPngImage instead of TJPEGImage, and 'png' extension instead of 'jpg'.
