How to completely disable header/footer editing?
Tavo
Post by Tavo »
Hey there!!! Salute from Buenos Aires and sorry for my bad english...
I need to work with documents that have a header and a footer that are stored separately (in another TFieldBlob).
I need both documents (header and ffoter) are read-only so that users can not modify them.
I tried with ....
   Self.SRV.RVHeader.ReadOnly := True ;
   Self.SRV.RVFooter.ReadOnly := True ;
It works, but anyway this causes two unwanted effects:
- It is visually indicated by the appearance of the editor.
- Editor header (readonly) takes focus
Is there a way to tell TSRichViewEdit only show the contents of the subdocuments and not allow to edit them?
Thanks in advance
Process SRV.OnChangeActiveEditor:
procedure TForm3.SRVChangeActiveEditor(Sender: TSRichViewEdit;
  ActiveEditor: TRichViewEdit);
  if (ActiveEditor=Sender.RVHeader) or (ActiveEditor=Sender.RVFooter) then
    Sender.StartEditing(srvrveMain)
Tavo
Post by Tavo »
This was exactly what I needed
It works perfectly
Thank you, Sergey
