how to use GStreamer
pgerbet
Post by pgerbet »
hello,
can you explain how use GStreamer, with your sample code.
How configure my windos computer for test,
beacause i say allways GStreamer, is not présent!
Thank you for your help
Best regards
Patrice
GStreamer must be installed from www.gstreamer.com.
If you create 32-bit applications, you need 32-bit version of GStreamer (even if you use 64-bit version of Windows).
No special configuration is required, but the default installer configuration may not install H.264 codec. When installing, you need to check options that sounds like "install codecs that may have patent issues" or similar.
pgerbet
Post by pgerbet »
hello sergey,
is ok now for gstreamer codec
thank you
