hello,
I must build spécific conférence system,
This sytem, is like system for internet school,
There are a master computer, with video server, with the client isntructor than send webcam course, and the student client view the webcam course.
so i would like known if is possible to,
1: / select orther source than audio microphone ?
the audio come from external mixer and is an audio line , not microphone.
2:/ send some time not webcam stream with audio line , but directly video with source like for example mp4 or some thing like this.
3:/ receive some time audio answer from student client with microphone
to master client and here that ?
thank you for your help .
best regards
Patrice
Audio selction
The current version of RVMedia use the default sound recording device for TRVMicrophone.
We already implemented selection from available audio sources (i.e. sound recording devices) in our version, but we need to complete some other work before uploading this version.
You can send video as a file, or TRVCamera can play the specified video file (TRVCamera.DeviceType=rvdtFile)
TRVMicrophone can also send WAV files.
hello sergey,
perfect for audio selection,
so, if i understood well can play video file like mp4 and then send via stream server.
is perfect to
with this i can play with audio and video input source for solve my request.
other question:
do you think possible to control audio input of the client via the server ?
I explain, i want control the the audio of student and open his audio flux (micro or other else) only if necessary, and if aggree that.
do you think possible ?
Thank you for your help
best regards
Patrice
is perfect to
other question:
best regards
Patrice
I am not sure that I understand about the microphone.
On the sending side:
You can turn reading from microphone on/off using RVMicrophone.Mute property (see the "microphone" checkbox in our videochat demos)
Alternatively, you can include/exclude rvmtAudio in RVCamSender.SendMediaTypes.
On the receiving side, you can include/exclude rvmtAudio in RVCamReceiver1.ReceiveMediaTypes. But it affects receiving audio from all clients.
