Addict Parser for 10 Seattle
I downloaded the most current package for the Addict parser from the website. It only has up to XE7 in it. I used the XE7 package and converted it for 10 Seattle. It built and installed, but when compiling a project I get an error opening "dialogs.obj" in C++ Builder personality. It does work in Delphi. Any ideas? Would it be possible to get an updated version of the parser with 10 Seattle?
Dialogs.pas is a standard VCL unit, so this problem is not directly related to thirdparty components.
Close your project in C++Builder, open its CBPROJ file in Notepad.
Find <AllPackageLibs> section.
It must look like:
<AllPackageLibs>rtl.lib;vcl.lib;RVPkgD10.lib;Addict4_RichView_dxe7.lib</AllPackageLibs>
(also, it must include Addict4 package, I do not know its name)
It must look like:
After further investigation, it seems the problem is that when I compile the parser, it is not creating the .OBJ files, even though I have it set to create all C++ Builder files in the package properties. Since the .OBJ files didn't exist, I think it was finding old ones and causing the error with dialogs.obj.
Also note that this is a brand new project that I created from scratch and just put the parser on and nothing else and it gives the error. After removing the outdated .obj files, I get an error that ad3RichViewCmpnts.obj is missing.
I don't know why the .OBJ files are not being created (I searched the HD for them and also tried specifying the output path for them when building the package.
Do you happen to have an updated parser for 10 Seattle I could try?
