Retrieving connected users on client side.
friman
Post by friman »
Hi
I have another question:
How can I know/detect on client when new user is connected to server?
Is there some way to let client to know about new "registered" users?
By default, a media server does not inform clients about other clients entering/leaving.
However, there are several mechanisms allowing to do it.
You should choose which one is more appropriate for you.
1. Groups of clients.
Groups are like chat rooms.
Groups are used in VideoChats\Chat demo (you can see, it uses OnUserJoinsGroup and OnUserLeavesGroup)
See http://www.trichview.com/help-media/trv ... ethods.htm
This topic explains how group members are informed about each other
2. "Default receivers" and/or "allowed senders"
Default receivers are used in all our VideoChat demos, but while "Chat" uses groups for managing lists of clients, "Messenger" and "Conference" use default receivers (you can see, they use OnUserEnter and OnUserExit).
See
These topics explain how such users are informed about each other.
friman
Post by friman »
Hi Serguey
Thanks for your reply.
Yes, I use these method, but they inform to user about the currents allowed by him, no about others (thinking on extended solution where users can banned, denied, allow,...access). That is why I ask if some way to retrieve ALL.
I now think that solution will be sent some command to ALL live users from server when new users connects.
On this case, I can suggest if is possible, on server side to clients:
- Retrieve info of connected users
- Retrieve info of live groups
- Retrieve info of live Cam
1. Informing about each other
You can implement a special group on the server (with some fixed ID), and all clients must join it. So they will be able to know about each other.
2. Retrieve information about users
By default, the server does not store any information about clients except for their ID, list of default receivers, and list of allowed senders.
You need to implement retrieving information yourself.
Online clients can send commands to each other (via the server) and you can implement information exchange in this way.
You can also implement storing information about the client on the server. Clients can send commands not only to each other, but to the server directly.
The example can be found in Demos\ClientServer\Login\. This example uses TRVMediaServer.OnServerCmd to store information about clients (login and password) in a database. You can store any information you need, and implement commands for requesting this information.
3. As for the list of active group.
On the server, you can process the commands for users joining and leaving groups, thus maintaining a list of active groups.
But I'll discuss with the developer how to simplify this task.
4. I am not sure what do you mean by "live Cam". If this is something on clients, you can implement exchanging information between clients using commands, as I explained in (2)
